How to generate 10V DC using 5V DC and -5V DC ?
danda821
Full Member level 2
Full Member level 2
question about dc power
I am wondering if there is a way to generate 10V DC using 5V DC and -5V DC. This is for IC design not pcb. Thanks.
You can use charge pump circuits to boost from 5v to 10v
Re: question about dc power
How. I have not other power sources, just use 5V and -5V. Thanks.
There is an application note from Philips (for NE555) that describes a simple dc-dc converters with it.
"NE555 and NE556 applications" AN170
Why can't you just use -5V as your reference and take +5V as the 10V line then?
you can use a charge pump and a few capacitors to generate 10V DC from +5V.
but current consumptio for +10V may not be too much.
maxim corporation's many RS232 related product use this technology
successfully.
good luck.
[/img][/quote]
charge pump circuit works like this way
fist phase VDC 5V connect to CAP+ and GND connect to CAP+
second phase VDC 5V connect to CAP- and VOUT connect to CAP+
then you get VOUT equals 10V
in fact, due to switch loss,VOUT is lower than 10V.
I think charge pump can do this work .but the cap must off chip.
