How to freeze the screen after running a C++ code (so it doesn't disappear)?
MusicMan
Member level 2
Member level 2
i'm trying to program a simple code. like the usual hello world. my problem is after running the code the (black)screen disappears. what i want is after the code is run the screen does not disappear so that i can see the result thanks
Re: pls help me dev c++
What I understand your problem: is that, your file (most probably in executable format) is stored in a folder, from where you execute it (from the DOS shell).
pls help me dev c++
Add the following code to the end of your main function...
system("PAUSE");
This is will hold the window open until you press any key
-jonathan
pls help me dev c++
AA,
Eiither execute your file from DOS ar add a scanf function at the end of the program, to close the window when you press an ENTER.
BR,
Amr Ali.
tnx for your help
