srikavis
Newbie level 1
I have 500Watts using SG3524, the problem is the output frequency is not stable as 50Hz. when i increase the load the the frequency also increases more, output voltage also i have to increase to 270v and above, otherwise it is not supporting more load,i replaced SG3524 also,can use SG3525 instead of SG3524.The battery charging voltage is 13v using SMPS Charger ckt. pls tell me how can fix this problem.:sad:
