Wamor
Junior Member level 2
Hello,
I am having some problems with a ADC circuit on my PCB.
When I read the ADC samples this gives a very unstable result.
The ADC is connected by an opamp circuit which converts a 0 - 20mA current
to a 0 - 3.6V voltage which is fed into the ADC121S21 from National Semiconductor (see atached schematic) . The current I am measuring is about 1.5mA created by a LM317 current-source. When I connect a 4.5 digit multi-meter in series with the current-source I see that the ADC-results are getting even worse.
The current measured by the multi-meter does not fluctuate as much as measured by the ADC.
Does anybody has some idea what is wrong here?
Thank you and best regards,
Wamor
Wamor
