Madhurakshi B S
Newbie level 6
Hello Sir/Madam,
I had a problem in uploading the Arduino code on to the board.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer as error and one more error which starts from -F (xxxx) check xxxxx...... I don't remember the complete error. I tried a lot to rectify this error. In one of the websites it said that uninstall the Arduino and reinstall for it to work as normal as before. I followed the same steps but now Iam getting compile error as "processing.app.debug.RunnerException". I need your guidance to rectify the error.
complete error is attached below
Thank you
Madhurakshi
Please let me what steps has to taken to clear the error.processing.app.debug.RunnerException
at cc.arduino.Compiler.callArduinoBuilder(Compiler.java:317)
at cc.arduino.Compiler.loadPreferences(Compiler.java:216)
at cc.arduino.Compiler.build(Compiler.java:175)
at processing.app.SketchController.build(SketchController.java:664)
at processing.app.Editor$BuildHandler.run(Editor.java:1632)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: Cannot run program "C:\Program Files\Arduino\arduino-builder": CreateProcess error=193, %1 is not a valid Win32 application
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.Compiler.callArduinoBuilder(Compiler.java:297)
... 5 more
Caused by: java.io.IOException: CreateProcess error=193, %1 is not a valid Win32 application
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 7 more
Thank you
Madhurakshi
