How to fix my GSM phone so it won fail Radiation Emission
xinxin
Full Member level 3
Full Member level 3
EMI problem
My GSM mobile phone failed at Radiation Emisssion Test , it is failed at 2nd harmonics when swept from 1G to 6G . How can i resolve it ? Its shielding is OK.
Re: EMI problem
Radiated Emission Test? Were you measuring harmonics level of the GSM phone transmitter? Or harmonics level of the receiver's local oscillator?
You must be more specific in order to help you.
EMI problem
Yes , RE is Radiated Emission , We are to scan the hamonics level of GSM transmitter.
Re: EMI problem
If this is the case, improved shielding will give no effect. Harmonics (overtones) from the GSM transmitter is caused by nonlinearities in the RF power amplifier (PA). A lowpass filter, located at the output of the PA would help.
Re: EMI problem
A filter located at the ouput is a good choice, but it will lower the output power.
Re: EMI problem
It is always better to solve the problem, not the effect.
/pisoiu
