how to fix iexplore home page site change automatically
binu G
Advanced Member level 2
Bangalore
i have a problem with my iexplore.
the home page change automatically to a different site.
how can i put a fix for the same
binu g
Spyware!
Search Google for "home page hijacking"
Hi. Try with ADAWARE.
Best Regards.
i tried the same
it was not allowing me to install the adaware
finially i installed it frm safemode.
and fixed the spy. but later when i tryed in normal mode the application close automatically.
iam not even able to search in the net for removal tools it automatically close the explorer.
such a stupid spy.
hmm
how i can fix it .
is the only way to format .
or any registray fix is there
binu g
Look for a file called "hosts" (without any extensions) in the windows folder and look what is inside this file (with a text editor).
Normaly it should only contain some explaination text.
This file can be used to redirect IP to another adress like this:
127.0.0.1 localhost
127.0.0.1 0-ol1oiz-xolxii1-oxli10ozl1l1-o-l-11-iizxp-l-0o-oll11iz0oil-ol.com
127.0.0.1 000freexxx.com
127.0.0.1 0190-dialer.com
127.0.0.1 08.185.87.0.liveadvert.com
127.0.0.1 08.185.87.00.liveadvert.com
127.0.0.1 08.185.87.01.liveadvert.com
127.0.0.1 08.185.87.02.liveadvert.com
127.0.0.1 08.185.87.03.liveadvert.com
127.0.0.1 08.185.87.04.liveadvert.com
If this feature is not used you should delete all entries, hope your problem can be solved with this.
best regards
Use "CWShredder" together with "HijackThis" will help eliminating all of your problems. But please be aware that this can also cause your system to unstable or even stop working if you delete any important item instead of Spyware.
Before you begin, you have to turn of system restore if you are using Windows XP. Then use these tools to check Spyware of your system. Read every step carefully and pay attention every time you try to delete any item.
CWShredder 1.56.2 (About 133 KB) **broken link removed**
HijackThis 1.97.7 (About 157 KB) https://www.spywareinfo.com/~merijn/files/hijackthis.zip
mr.C-MAN
it havent helped.
i have deleted those files still no.
iam using the winxp
the fun is that iam not able to download the link provide by Mr.Amuro
once i click the link it closes it automaticly.
and a stupid page apear every 1 minute
please dont click the link
any way to fix it
binu g
CWShredder works. I had the same problem and it solved that.
It dosent allow me to download that link
when i start for a download for a spyware it simply close the internet explore
even tried to download using netvampire. after download the file is missing . its really surprising.
binu g
Ya. Talking about spyware. I have some experience just last week. I was wodering why my tray icon consists of stange icons (2 in total) shown some progress in %. I bring up the close program dialoge box (ctrl-alt-del) and killed all the task. Disconnect from internet. Do a search in system registry using the name shown in 'close program' dialoge. Then I was able to locate all the entry that had them run automatically each time I start windows. I was able to locate where the spy hide in my HD and prepare a cemetery for them.
go to start and run , type msconfig and see which programs run at startup and switch of suspicious programs
in my experience iexplorer is quite vulnerable to these types of attacks. usually i just do a reinstall of windows when such things start to happen. i know that this might not be the most elegant option available.
but i have come up with a better solution. i always keep a couple of other browsers. whenever iexplorer starts to do things like this i start using the other browsers. then if a fix in the registry or an ADAWARE search cant fix the problem i do a clean install of windows when i get the time.
i say just leave iexplorer and install some other browser. or u can fix your registry. did u make a checkpoint for system restore?? if yes then just simply do a system restore. that might be the easiest of all the options
check out if there is a .dll that has strange name, 30KB, most recent modified datetime, in windows\system32\. delete it then edit register file in sofware->microsoft>internet explorer->main. you'll see the links.
btw, maybe that .dll is not allowed deleted, use task manager to kill explorer.exe, then cmd get into windows\system32\ to delete it.
frankfan
the first terrorist in the world is Bill G....
every day I spent time for resume win os in my computers
look at the time stamp of dll's in the directry...the malicious ones will be of a latest possible dat..usually..different from system files...so delete them..
h**p://www.casinopalazzo.com/index.php?sourceid=103061
binu g
Actually, the links I provided is used to be work, it is the official page of the developer of these tools. But now it down with unknown reason. Sorry that I didn't check it before let you know. I think the page you see may come from one of your spyware, not from the link itself.
Anyway, you can use this link instead, https://www.softpedia.com/public/cat/10/17/10-17-150.shtml (CWShredder and HijackThis) or https://www.majorgeeks.com/downloadget.php?id=4086&file=3&evp=6742c4ccda2599a3d6c5901960cc6e24 (CWShredder Only). There are 100% save and work. These sites also include many other tools to fight with spyware.
frankfan
:cry: it even dont alow me to run regedit.
or msconfig. i tried puting firewall but failed.
binu g
well in that case i recommend that u run system restore. that is if u have made a checkpoint before. or else just do a clean install of windows.
