How to fix Coax Cable of Vector Network Analyzer?
swadesh07
Junior Member level 3
Hello,
We have Vector network analyzer that goes from 10MHz to 67GHz. For last couple of weeks, one of the coaxial cable is fluctuating a lot. As we know a new coax cable at this frequency is very very costly. So I was wondering is there any way to find the problem, root cause and any procedure to fix that cable. Thanks in advance.
Regards
Swadesh
If the cable is broken down, all you have to do is to replace with a new one.Coaxial cable are not repaired especially measurement grade ones..
The problem may come from the connector junction, have you ever checked it out ?
