All MAX 7000 devices contain a programmable security bit that controls
access to the data programmed into the device. When this bit is
programmed, a proprietary design implemented in the device cannot be
copied or retrieved. This feature provides a high level of design security
because programmed data within EEPROM cells is invisible. The security
bit that controls this function, as well as all other programmed data, is
reset only when the device is reprogrammed
