How to find slope at a point "X" on the given curve.
ravi1488
Member level 3
Member level 3
India
Hello All,
How to find a slope at any point on the curve?
I have a curve which is almost negative exponential curve. I have to take a point on the turning point of the curve and then find a slope at that point of the curve. From that point I have to take a tangent line. How I can do that?
What defines the "curve"? An anylytical function? An empirical measurement?
Re: How to find slope at a point "X" on the given curve.
Please see the above image
We have points A, B , C etc.
You're not exactly answering my question.
I assume the drawing means that the curve is given by points A to G. So strictly speaking, the "curve" is only your imagination. In this case you need to interpolate the curve with a suitable differentiable function to calculate the slope. Or use the slope of the line connecting points C D as a first order approach.
hi ravi,
IF the plot is on scaled paper, a measuring rule place on the paper plot would have to be just touching the plotted point and the intersection of the rule with the X and Y coordinates would give you a value from which you could calc' the approx slope.
Again if you know the scaled values, you could try the straight line equation y= mx+C.
E
Assuming you want a precise slope for ANY value of X, I find the easiest way is Excel.
It only takes me a few minutes with data entry, plot, curve fit with polynomial & display equation, create product terms of derivative of Y(x)
Enter new x, display dy/dt = slope.
