How to find sampling frequency of dspic
P.Copper
Member level 5
Member level 5
Hi all,
1) I have Fosc=60Mhz which results to Fcyc=15MHz
2) I set ADCON2=0 ,ADCON3=0
from this information i want to calculate my sampling frequency. how can i calc that? i've checked the datasheet of dspic30F family but i don't understand how to go about calculating it.
Maximum PIC30F sampling rate is 1 Msps for 10 bit and 200 ksps for 12 bit converter. Setting ADCON for a higher conversion rate doesn't result in correct ADC operation.
Thanks FvM, What do you suggest i do
Set the ADC control registers as suggested in the datasheet and family reference manual.
