how to find out the output of d flip flop
vead
Full Member level 5
Full Member level 5
india
when the value of flip flop input are known how to find out the flip flop output I want to find out the output of d flip flop
truth table
D Clk Qn| Qn+1
0 0 |
0 1 |
1 0 |
1 1 |
how to find out Qn ?
how to find out Qn+1?
You need to expand your truth table to include the value of CLK before and after a transition. Qn does not matter when deciding what Qn+1 will be. Qn+1 will be the same as D whenever CLK goes through a transition from 0 to 1, provided that value of D remained constant during the setup and hold times around the CLK transition. And Q will remain in that state until the next 0 to 1 transition on CLK. (Note: some D flip-flops use the opposite transition of CLK, from 1 to 0.)
The link below will open an interactive simulation of a D flip-flop (master-slave configuration).
Click the single input (L or H) at extreme left. Watch to see at what time the output changes.
https://tinyurl.com/kwl4pgu
This is one of the circuits included in Falstad's animated simulator. Free to download and use at:
www.falstad.com/circuit
if clock=1
D Clk |Qn
0 1 | 0
1 1 | 1
and if clock=0
D Clk |Qn
0 0 | 0
1 0 | 0
check out table if i am wrong correct me
If we look closely at your table, it appears the same as an 'AND' gate's.
The D flip-flop is a clocked device. Its gates are configured to wait until a clock transition, to change state.
These scope traces demonstrate its behavior. Your truth table must show the same responses.
