Run a dc analysis. Then go to 'Results'-> 'Print"-> 'Model Parameters'. Then select the corresponding transistor in the schematic. To calculate the Cox value you need to use tox(thickness of oxide).
Cox=E0*Er/tox
E0=8.854e-11F/m
Er=3.9 for SiO2
and Tox u can find in the listed parameters.
