richaphy
Member level 1
I have designed a complex filter in cadence and want to find its image rejection ratio. Can anyone please tell me how to do it??
Thanks in advance
Thanks in advance
Dear LvW
Can you please elaborate the method.
1) I am not able to understand what you mean by by perform two anlysis , do you mean that i should do two differnt analysis while giving normal/ usual values in the first, giving the changes values in the second analysis, then compare the results of the two??
2) About the input, Vin=V1+jV1 (90deg lead), Vin=V1-jV1 (90deg lag): I must give AC magnitude value 1 and change the phase to 90 and -90 degress only???
Thanks in advance
Positive Frequency Stimulation (phasor rotates counterclockwise)
Mag 1.0 Phase 0.0 for the in-phase component & (signal name "I")
Mag 1.0 Phase 90.0 for the quadrature-phase component (signal name "Q")
the second
Negative Frequency Stimulation (phasor rotates clockwise)
Mag 1.0 Phase -90.0 for the quadrature-phase component (signal name "Q")
