prathamesh29
Hello,
A bandlimited analog signal is sampled (with no aliasing) at 500 Hz and 980 samples are collected. The DFT of these 980 samples is
computed. Find the value of the spectrum of the sampled signal at 120 Hz ? (a) Which DFT index k is nearest to 120 Hz, and what is its physical
frequency in hertz?(b) What is the minimum number of zeros we must pad onto the 980 samples to obtain a DFT value at 120 Hz exactly? What is the DFT
index k then corresponding to 120 Hz?
Here I calculated k :
fs/N*k=120 so , k=235.2. And the nearest value to 235 is 119.89 Hz.
I am unable to proceed further for padiing of zeros. Kindly, help me with this. Also , what generic equation does a bandlimited signal have (in case we want to plot this using Matlab)
Best regards,
Pratham
Best regards,
Pratham
