How to find appropriate replacement for a RF amplifier?
actra
Member level 5
Member level 5
cairo [EGYPT]
replacement for rf amp.
1- what parameters should i worry about when trying to find a replacment for an RF amplifier ?
Re: replacement for rf amp.
These are some of them:
-Supply voltage and current consumption
-Output Power and Input Power
-Linearity
-Gain
-Frequency range and Bandwidth
-Power Control Range (if exist)
-Efficiency (if is important)
If it is used on cell phone.
You should take care
-power ramping coefficient
-band select timing
-Tx enable timing
-Front-end enable timing
-Input level range
It depends on which field is based the application.
In my field for example are very important:
1) frequency range
2) Output power
3) Harmonics
4) Maximum input power
5) power supply voltage and current
6) Dimensions and shape
7) Operating temperatures
8) Vibrations spectrum
9) Altitude
10 ) Maximum antenna mismatch and mismatch protection
11) Type of modulation
Mandi
