How to Filter this Image in MATLAB?
panda1234
Full Member level 2
Full Member level 2
Hi, I have the left picture and i want to filter like right picture.how i do this in MATLAB?
You could do this by checking each pixel and comparing it to the adjacent pixels. This will help you decide if the black pixel is in the black square or not, same for white pixels.
but is this way true on boundary?
on boundary of squares: yes, because you have special conditions there, you know that adjacent pixels will be half black & half white!
hope it helps
in MATLAB don't there any filter command for this?
maybe we have a little black line and in this case every adjacent is ok but we know this is noise.
I want to find right pattern in left picture but i don't know how to do this.
What you want to do is essentially apply the pattern picture on the right at the target picture on the left, so that will act as an arithmetic or logic filter. For the example above, you should use some Pattern Matching algorithm just for obtain the exact place at where you will superimpose one over other.
