vishal_sonam
Full Member level 3
hello
i want to know that how to fabricate the aperture coupled antenna.
as i know in aperture coupling, the ground plane is separated by two substrate or we can say ground plane is use to be situated between two substrate.
so for fabrication process if we use single side FR4 sheet if we want to fabricate using Fr4, one side of the sheet act as ground plane so lower part will be substrate then ground plane but then what we will put above the ground plane.?
i hope you got my question.
regards
regards
