how to extract dvju files?
suvendu
Full Member level 3
Full Member level 3
.dvju
extract djvu
These files are looked at with a plug-in on web browsers. There may be a method of converting them to another format.
how to extract djvu file
Can you point to a tried and tested plugin.....I tried one but failed.
djvu file extractor
I only did it once and with netscape navigator. This was several years ago.
djvu extract
try to right click on the file " in windows"
and select "open with"
you may then try " look up for an appropriate program using web"
this will open a new page in your browser and bring up a vast number of applications used to open up djvu files.
try windjview.
DJVU is marvelous :D
djvu extractor
djvu is one of the type of document format (like doc, pdf,..etc).
You can view this file using a free software provided by "www.lizardtech.com"
Go through the website you can explore more about djvu!!!!!
Djvu is having more compression raio than pdf, doc..etc...
extract djvu file
Well DJVU has a higher compression rate only concerning pictures and scanned documents.
When it comes to text files converted into pdf the compression rate is the same in pdf as in DJVU.
I tried it to make sure:!:
how to extract djvu files
About information of djvu, surf to www.lizardtech.com. There are explanation about this technology, downloadable plug-in browser and so forth. It's a good technology to compress scanned images.
dvju files
enogogo said:
DJVU is a text format... google to find some reader.
Hi
Djvu is not a text format, but it has a text meta-layer. This text meta layer may be extracted.
tnx
