Alex Liao
Member level 4
Hey,
I am using Cadence IC 6.1.6. The waveform or the plot is generated by
Virtuoso (R) Visualization & Analysis XL.
I have a plot which is gm/id (y-axis) Vs Id/(w/l) (x-axis) by doing a Parametric Analysis of sweeping Vgs.
I found in the result folder, it has lots of sub-folders named as Vg=0.111,..., Vg=0.555, Vg=0.666,..., Vg=0.999. Inside each of them, a /psf folder is there. This is reasonable as plenty of DC points are covered in the Parametric Analysis. Therefore all of those '/psf' result directories' are working together to compose a full plot by providing data and maybe do some interpolations.
I want to extract a value from this big plot and do not know how to do it.
Say, I can read when the X which is id/(w/l) = 5u, the Y which is gm/id = 10. But I want to get Y values by providing X values.
I am thinking, since the X-Y in the big plot are one-to-one corresponded, if all the data are summarized in one place as an uniformed waveform or maybe a big table, then giving a X and asking for a Y should be straightforward.
I am not quite sure if the waveVsWave will summarize all the data and provide a function to access it.
If ocean script can do this, that's best.
Any idea?
Regards,
Alex
Any idea?
Regards,
Alex
