How to export strechable figure?
neoflash
Advanced Member level 1
Which tool can translate figure into the format which won't become vague when streched?
thanks
if it's a rastor image, then no tool can help you unless you can find one that can convert from rastor into vector.
you should try to save your image as an eps file which saves the vector info, hence you can resize it without pixelation
    neoflash
