farzad_
Newbie level 1
Hello all
I have designed a patch antenna in FEKO and I want to export it to gerber file to manufacture it. The only option i see is export mesh. But when I use this option in FEKO, and then I open it with FEKO to see if it is ok, the structure has many errors! it is NOT exactly the same as original structure. Do you know how to export gerber file using FEKO? I even changed the mesh size but it didn't work. Thanks
