does anybody know how I can execute feko in a linux machine? I installed the software and licence successfully, but I can't use the runfeko command as it has to run it first. Please let me know if anybody is using it...
I remember that it was a 2-line command but I can't find it out right now...
Hi di you ever get feko to work in linux? If so can you give very specific instructions on what you did to resolve your current issue? The reason being that I am experiencing the same issue at the moment.
There is no real speed improvement in Linux over Windows, but Linux's memory management is better - you would probably be able to run models with a few hundred MB's more memory in Linux compared to Widows.
