How to exec and system in C ?
yhboy
Newbie level 3
Newbie level 3
Hi
I would like to use exec or system to do a dos command:
copy <file1>+<file2>+<file3>.....<file N-1> <file N>
How to do that?
Re: exec and system in C
This should work fine:
#include <stdlib.h>
int main(void)
  system("copy file1+file2+file3 outfile");
  return 0;
I don't know about exec, there is no such thing in ANSI C.
Or were you asking how to generate a string with all those "file..." words in it?
#include <stdlib.h>
int main(void)
  return 0;
Thanks
But I want the number fo file is adjustable, not limited in 3 files.
The file1, file2 ..and so on are the arguments of main function.
#include <stdio.h>
#include <stdlib.h>
int main(int argc, char *argv[])
  int n;
  char buf[1000], *p;
  /* This lacks checks for too-few arguments, or buffer-overflow */
  p = buf + sprintf(buf, "copy");
  for (n=1; n<argc; n++)
    p += sprintf(p, "%c%s", (n==1 || n==argc-1 ? ' ' : '+'), argv[n]);
  puts(buf);   /* Change "puts" to "system" in the final version */
  return 0;
I hope that wasn't your homework!
echo47 said:
#include <stdio.h>
#include <stdlib.h>
  int n;
  char buf[1000], *p;
  return 0;
Thanks a lot.
That is not my homework.
I just want to know the usge of "system()" because I found the system function is like this:int system(char *command)
It is ok when executing command like "dir" that contains no argument.
But I don't know how to do if the command contains arguments(something like what I asked)
Anyway, thanks a lot.
exec() and system() are both Unix system calls.
The difference is that system() can be used to execute any unix command as if you type it at a shell command prompt. You just pass a single string.
e.g. in your C code
system("xterm");
When the system is executed, an xterm will be launched. Default shell is sh so only those command known by shell can be run.
exec() can do the same but it gives you more control. You can specify path to an application and pass arguments to it. For example, if exec() fails to lauch the xterm, the path you specified could be wrong. Like I said, more control.
