How to excite coaxial cable with signal generator 50 Ohm?
sina
Member level 1
Member level 1
cable
hi
I want to excite coaxial cable with signal genarator 50 ohm.How I must match it.
thank you
Re: cable
I want to connect signal generator to coaxial cable.This signal generator has output impedance 50 ohm and it is not matc with coaxial(75 ohm).I want a ciruit to match them.
Re: cable
My frequency is about 10Mhz and I have wave return in this frequency and lenght of my cable is about 6 meter.
Re: cable
You can match your 50 ohm generator to the 75 ohm cable with a so called "minimum loss pad" (MLP), check the topic:
regards, Al
Re: 75 ohm cable match
You can use a 50 ohm to 75 ohm transformer (impedance ratio of 1.5):
See also these notes:
cable
Technically speaking it's possible.
Economically speaking it isn't convenient.
This beacase both the solutions proposed, especially the minimum loss pad are lossy and expensive solutions.
The 75 Ohm cable has lower loss (with same outside diameter) than 50 ohm cable, but with 2 minimum loss pad or 2 transformer you lose more that the gain!
Also consider that for a good match you need coaxial connectors.
Each pad or transformer need a couple of connectors (1 50 Ohm, the other 75 Ohm).
