I am using a simple transformer. When I press ctrl+E, but tell me that how can i calculate these values like primary inductance, secondary inductance etc. Can you suggest me some calculator for this purpose?.
wanna calculate inductance in proteus or of real transformer???
in proteus by default values are set to 1.
for primary voltage use 'alternator' and set value to 220v and 50Hz.
secondary voltage can be set by changing the trans properties; coupling factor Coupling Factor
