How to edit and save library in eagle
Fan174
Member level 2
Member level 2
It's pain to find the required library in eagle CAD so I want to make my own library from existing library Eagle 9.3
I would like to add something simple e.g an capacitor . There are many existing library available for capacitor in eagle library I am trying to make new library from the
I am following this link https://forums.autodesk.com/t5/eagle-forum/edit-and-save-library/td-p/7312931
control panel > File > New > Library
In the table of contents view at the bottom of each of the 4 columns
I get four buttons new device/footprint/3Dpackage/Symbol.
I can't seem to figure out how to open a part, edit it and save it as a new part
What am I missing here? Any help would be appreciated.
Thanks
the recommendation is to use an existing library, copy it, then edit it.
But from your description you try to generate a new library from the scratch.
Klaus
Reactions: Fan174
    Fan174
Klaus
Hi Klaus
Thank you for the advice
I want to use existing library , copy and then edit it.
I have done two step's Please check screenshot
What I should do next steps
if it doesn´t work the way you try then
* either copy the library in WINDOWS.
* or OPEN the library then SAVE AS xxx.lbr
Klaus
