How to easily convert +28V to +33V supply ?
djnik1362
Full Member level 2
Full Member level 2
IRAN
hi
We have a +28V supply in our system and we need a single +33V
in our circuit . Is there any simple solution that we use to provide
desired voltage ?
thanks.
Re: Convert +28V to +33V
Yup. Design a boost converter to boost the 28V to 33V.
hi
desired voltage ?
thanks.
Hi djnik1362,
Is this SMPS?if there is a trimpot for trimming the output,you can adjust it by turning the trimpot then measure the output voltage.Some SMPS has a trimpot to trim the output.
regards,
spectrum17
how much current you need?
Hi djnik1362,
regards,
spectrum17
i don't know. What the SMPS is ?
SMPS = Switchmode Power Supply
Check this out for more info: **broken link removed**
yes. i prefer to use switching supplies.
---------- Post added at 03:37 ---------- Previous post was at 03:34 ----------
thanks but i want to use devices such a step-up DC/DC converter.
i can't design any supply.
They will help you to design. Web based.
---------- Post added at 03:44 ---------- Previous post was at 03:43 ----------
@djnik1362
do you have schematics about your PSU?
Is is the 28V output comes from SMPS?If yes you can provide schematics so that i can help you to modify it from 28V to 33V.Since it is only increase with 5V the voltage divider reference can be trimmable.
