how to drive a table or ceiling fan with 12 volts rechargable battery source
rajaram04
Advanced Member level 3
earth
Hello sir
i want to drive aceiling or a table fan without using invertor but with a 12 volts battery & circuitries related . .
please help
you cannot do that simply !!
the motor in the ceiling and table fan is AC , and battery is DC . you will need an inverter and preferable puresine wave . you can design your own if money is an issue.
by the way there are some small table fans operated by batteries , these contain dc motors and ready . you can also search for fans for cars as these are also dc operated .
hope that helps
cheers/
hope that helps
cheers/
hmm yeah i know it needs an invertor to execute but what about the diagram ?
i know about such fans & too i made that earlier but now moving ahead in practicals to do so with a.c. fans
i want to run single ac fan at a time so what would be the circuit diagram ?
how ll i get that ?
