How to drive 5V IC through Cyclone
Re: Cyclone doubt
as per cyclone handbook
"A Cyclone device may not correctly interoperate with a 5.0-V device if the
output of the Cyclone device is connected directly to the input of the 5.0-V
device. If VOUT of the Cyclone device is greater than VCCIO, the PMOS
pull-up transistor still conducts if the pin is driving high, preventing an
external pull-up resistor from pulling the signal to 5.0-V.
Cyclone device can drive a 5.0-V LVTTL device by connecting the
VCCIO pins of the Cyclone device to 3.3 V. This is because the output high
voltage (VOH) of a 3.3-V interface meets the minimum high-level voltage
of 2.4-V of a 5.0-V LVTTL device. (A Cyclone device cannot drive a 5.0-V
LVCMOS device.)"
    yamaha
Re: Cyclone doubt
that means i can interface 5V i\Ps without any problem
Re: Cyclone doubt
U can also go through the document
    yamaha
Re: Cyclone doubt
thanks for the info, what shud i do when i have to drive a 5V IC with cyclone
Re: Cyclone doubt
use level translator 3.3 to 5
    yamaha
Re: Cyclone doubt
SN74LVC4245A FROM TI
IDT74FCT164245 FROM IDT
U CAN LOOK FOR 164245 SEIES IN PERICON TOO
    yamaha
