How to draw via by using ADS momentum?
kpcheah
Newbie level 6
Newbie level 6
Hi
i am very new to ADS.
i would like to draw via to ground can anyone help?
Thanks
You have to have to fisrt set up a via in the substrate block between the two conduction layers. Then you can draw it in any shape you want.
Drawing a via is same as the drawing of any other shapes because its just 2D editing.
Let say to have via draw with a different layer and assign for via in defining the substrate and layers in momentum.
edit layers---->create the shapes---->assign via ----->add it into substrate create
