how to draw triangle in HFSS?
geppei
Junior Member level 3
hfss equation based surface
Could anybody know it?
Thx
equation based surface hfss
Salam
I have used the HFSS, though not much. Still I am learning about it. According to my experience you can not draw the triangle it self. But if you want to make some conical shape that is possible. As in the case of horn antenna just it is matter of conecting the surfaces.
Regards
Asim
how to draw trapezoid in hfss
just go >draw>line and draw a triangle formed
by three lines but make sure you close the
surface. If the surface is not cover go to
>3Dmodeler>surface>cover faces....
triangle hfss
you can also use equation to draw a triangle.
Draw-> equation based surface
or
Draw-> equation based curves.
Based on my view of points, the latter is more accurate than the first.
draw triangle in hfss
its simple u can use coordinate entry method and draw triangle and then fill the enclosed area
hfss draw triangle
double click after you have drawn 3 points and 2 lien segments.
formula to draw triangle
Use Draw line to form trangle or any other geometry in 2D. Then Select the object, copy it and paste to get a duplicate. Now use move to position for the desired thickness. Then select the two oblects (Control + click), from the menu select 3D Modeller > Surface > connect to get the 3D model.
