I want to get 5V 100mA DC from 3-phase 380V mains without using transformers. I tried capacitor-resistance in series and 3phase bridge but can't draw so much current.
I'm trying to get power for my board without using transformers to keep it low cost, I do not need galvanic isolation for this board.
In ths case I would select only 1 phase and neutral, and use the attached circuit with the following changes:
FS - 250mA
FR = 0
R1 = 10Ω
C1 = 3µF
ZD1, ZD2 = 8.2V
C2 = 470µF
ZD3 = 5.1V/5W
Regards,
IanP
I suppose that circuit for 3 phase 5 V wont work . Once capasitors charged then wont transfer charge in forward direction through diode .
And also that circuit on picture is not optimized
2 Sobakava . Take a look to converter alike solution (let say chargers for ericsson mobiles ) . They are littel bit more complicated than what you are trying to do .
