How to double(quadruple) frequency which is no 50%duty cycle
twlin1
Member level 1
Member level 1
If there is a waveform which is not 50% duty cycle, like 20%(80%), how to generate its double or quadruple frequency with the same duty cycle?
Thanks in advance.
Re: How to double(quadruple) frequency which is no 50%duty c
How about this:
1. From picture below signal A is the original clock wave form.
2. Use DLL with a center tap to lock on to rising edges of signal A to create signal B.
3. AND signal A & B to create signal C.
4. Use a second center tap DLL to lock on the rising to fall edges of signal C to make signal D. You need this since even though the picture looks like 50% duty cycle, this won't be the case in general.
4. AND signal C & _D_ (inverted D) to generate signal E.
You can extend the concept to make 4x clock.
    twlin1
Thanks. It helps much!
