how to do ideal bias voltage for CMOS circuits??
wael_wael
Full Member level 4
Full Member level 4
Hi everybody,
thanx
it is by maintaining your MOSs in the region of operation you want.... but current source biasing is better for MOS devices...
ok, i am try to bias my OTA without bias circuit, could you help me to that
thanx
for these kind of applications current mirror is the best way.... please post your proceeding in that particular ota....
    wael_wael
fully differential folded cascode OTA
take a unit bias current which is usually generated from a bandgap, then use this current to generate all the bias currents and bias voltages.Always look in terms of bias currents and not voltages.When i say this i mean, try to flow a particular value of current which you intend and then keep scaling the size to achieve minimum overdrive.
amarnath
    wael_wael
i agree with amarnath.... that is what is usually done in CMOS circuits.... it is where we can bias a circuit to a particular region of operation using current....
I'll try and post whatever i can on ota circuits....
Regards
Anand.
    wael_wael
You can use bandgap reference circuits for stable temperature compensated output voltage
    wael_wael
