How to do "DONT_TOUCH" in MAGMA
au_sun
Full Member level 2
Full Member level 2
i am working on P&R(placement and routing) in Magma,
i have a requirment of keeping a sub-block under the top module as dont_touch
how to do "dont_touch" in magma ?
i request edaboard members for ur kind help.....
u wanna place all blocks in hier-.
in partitionally phase u can do it.
i saw regarding that in Demosondemand once.
aravind, i want to keep only the netlist as such and no separate partition required in the floorplan,
dynamicdude, i tried using "force keep -content" command, but the problem is , in the layout, the pins belonging to the "kept" netlist are not connected, they are open in the layout,
so is there any other way to do "dont_touch" option in Magam
Hope this exmaple help. It force keep all the cell in instance core/clk.
set keepList [ data find $m core/clk/* -type cell ]
foreach keepItem $keepList {
force keep $keepItem
Regards,
Eng Han
Hi au_sun,
Just hide them.
Hiding a model prevents that single model from being used.
Hiding an entity prevents all the models within the entity from being used.
The command is:
force hide entity | model
Example:
force hide $l/AND5
force hide $l/AND5/AND5X4
hi au_sun,
your meaning is just keep hierarchy for one block in netlist? you can using
force maintain
