how to do counter that stops at a certain number
elec-eng
Full Member level 5
Full Member level 5
how to do this
hi friends
I'd like to do the following using vhdl
for the first 40 clock cycle the output is zero
after that the output is 1 forever
I know that I can use an FSM
but it will has 40 states
so any other idea?
thanks
Re: how to do this
Why would it have to have 40 states? You can have one state that counts to 40, and upon reaching 40, it goes to the next state where your signal is set to one, and it stays in that state until the block is reset, or some other condition of your choosing.
Having said that, you just need to have a counter that counts up to 40 and then stops. When the counter is less than 40, your signal is zero, and when it is equal to 40, it is one.
r.b.
how to do this
thanks rberek
but how to design a counter that stops at a certain number (40 in my case)
Re: how to do this
Here is the code
entity count_40 id
port( clk,reset :in std_logic;
op :eek:ut std_logic;
end count_40;
architecture arch_count_40 of count_40 is
signal count:integer(0 to 41);
begin
process(clk,reset)
begin
if (reset= '0') then
count<= 0;
elsif(clk'event and clk='1')
count<= count+'1';
else count<= '41';
end process;
op<= '0' when (count<='40') else '1';
end arch_count_40;
Dont forget to press the "Helped Me" Button
    elec-eng
Re: how to do this
prathiba's code will work, but not written in a efficient way, I just wrote it in FSM approach and here the counter will not toggle all the time while clock is running.
parameter [1:0] reset = 2'b10,
count = 2'b00,
no_count = 2'b01;
parameter count_num_param = 40;
reg [1:0] state, next_state;
reg next_count_number, count_number;
always@*
begin
next_state = state;
next_count_number = count_number;
case(state)
reset :
next_state = count;
count :
begin
if(count_number != count_num_param)
begin
next_state = count;
next_count_number = count_number + 1;
end
else
begin
next_state = no_count;
next_count_number = 0;
end
end
no_count :
endcase
end
always@(posedge reset or posedge clock)
if(reset) begin
state <= reset;
count_number <= 0;
end
else begin
state <= next_state;
count_number <= next_count_number;
end
assign signal_o = state[0]; // o/p signal
Regards,
dcreddy1980
    elec-eng
Re: how to do this
This seems the easiest to me...
architecture rtl of count40 is
  signal count : std_logic_vector(41 downto 0);
  signal hit40 : std_logic;
begin
  process(clk,rstn)
  begin
    if (rstn = '0') then
      count <= (others => '0');
      hit40 <= '0';
      if (unsigned(count) <= 41) then
        count <= count + '1';
      else
        -- once we get here hit40 stays '1' and counter stops
        hit40 <= '1';
      end if;
    end process;
end rtl;
    elec-eng
