How to do byte alignment?
davyzhu
Advanced Member level 1
oriental
Hello all,
What may cause wrong byte alignment? And how to do byte alignment generally?
Thanks!
davy
Last time friend of mine reported a problem with reading of data through pointer from memory . He did receive MSB bits instead of full number . The problem was only related to floating types if i am not wrong . Other types are read OK .Platform was ARM .
As far as i know aligment is not not specified in C standard thus implementation specific keywords could be used to make it . At least said is true for assemblers .
Check pragma attributes for specific compiler if it is complied with C standard where implementation specific addons to be defined through #pragma .
really depends on the microcontroller/processor.
some microcontroller prefers to store data at even addresses, for e.g.
you should check through the documentation of your microcontroller..
In may processors 4 byte should start at an address that is multiple of 4 (ends with binary 00), 2 byte at multiple of 2 and byte anywhere. However it possible to load the data other wise. This may be onereason.
The other may be due to the format of data storage, many processors store lower LSByte at a higher address and MSByte at a lower address. (Byte addressable ..)
To avoid problems check the data storage format before programming.
Hope this helps.
brmadhukar
Depends on compiler. For most C compilers you can use directives #pragma align, #pragma pack, and specifier "__align" to control alignment of different data items, structures and its members.
