how to do bit shift in __int64??
boeysue
Full Member level 3
Full Member level 3
bitwise shift __int64
__int64 i=0;
i>>=9;
why i is not 0??
and how to do in the right shift??
__int64 to zero
divide it by 2
__int64 shift
Is this C? That __int64 sounds like a language extension provided by your compiler. If it is a 64 bit integer type, then your right-shift should work fine. Maybe the way you tested i is incorrect. Tell us which compiler you are using, and show us a small complete program that demonstrates the problem, and maybe we can help you find the trouble.
For example, MinGW (gcc 3.4.2) provides __int64, and this correctly prints "i is zero":
#include <stdio.h>
int main(void)
  __int64 i=0;
  i >>= 9;
  if (i == 0)
    printf("i is zero\n");
  else
    printf("i is not zero\n");
  return 0;
hi,
I have also checked on sun compiler it is working perfectly fine,....
hi all
also working fine with MinGW 2.05(under winxp)
