How to Display Results?
Hi
I have designed a spectrum analyzer with a DSP.
The DSP performs FFT in 1024, 512, 256, ... number of points.
and the frequency span also can be changed. So number of results depending of the span and resolution can change.
I send the result to PC to display.
Because of limited resolution of display(i.e. 400 pixels) i should do a resampling on the results and then send them to PC.
i am looking for a code to do this resampling with arbitrary resampling ratio.
Thanks in advance.
