How to disable Windows USB 2.0 controller?
hani salehi
Member level 2
Member level 2
IRAN - Isfahan
Hi
I want to disable my windows xp USB 2.0 controller
how can i do that ??????
disable usb 2.0 /sys
If you want to disable USB Controller - Hardware, goto device manager, select USB controller, right click and disable. Or you can uninstall the drivers.
Re: Disable USB 2
No................
I want to my usb port works on USB1 protocol
:D
Re: Disable USB 2
USB 2 interface can work with USB 1 device, what is your problems?
Re: Disable USB 2
I have a HP Laserjet 1020 printer
It has a lot of problem in windows xp SP2
on systems that i can disable usb 2 in the system setup , it works good
but on my laptop ( DELL 640m ) , i can't disable USB2 .... and it has problems like this :
when the print job needs more buffer ( for example a lot of paper ) , the printer prints some 5-10 paper and then i can not print more , ( i must turn off and on my printer ) ....
:D
please help me
Re: Disable USB 2
Please down load the new driver for that printer here:
Re: Disable USB 2
goto control panel\system
click on hardware list
right click on usb controller
click disable
Re: Disable USB 2
OHH !!!!:!::!::!::!::!::!:
If I disable the usb controller , It will not work later !!!
