I_THINK_ITS_SHORTED
I'm working on a project and I need to completely disable the refresh of the Altera DE2-115 SDRAM, which would allow me to measure retention time of the SDRAM cells.
So far I have tried modifying the SDRAM_REFRESH_PERIOD in Qsys under the SDRAM timing settings. I tried setting it to 0, and I also tried setting it to very high values.
I then tested the SDRAM memory retention and regardless of the what I set SDRAM_REFRESH_PERIOD to it retains any data I write to the memory.
What I want to happen is that when I write to the memory, the bits revert to their previous state over time, since the capacitors are not being charged via a refresh.
Any help with this would be much appreciated.
