How to directly interface 220C AC line by micro?
BabyTiger
Full Member level 2
Full Member level 2
Interface AC line
How I can directly interface 220V AC line by microcontroller for detecting zero crossing. Pls advise example circuits which have safety and robust circuit.
Interface AC line
U hav to build a zero corssing detector circuit .. only when the voltage on the line is 0V the microcontroller can access the line .. tats the safest method to carry on power line communication.
Re: Interface AC line
If you are using a PIC micro controller you can directly conect AC power line for detecting zero cross through 20 mega ohm resistor in 220VAC and 5Mg resistor in 110VAC. then zero cross can be detected through software.
Interface AC line
yes...you can, see app. notes to microchip.com, which explains each deatils pretty well.
Thank, Pls give me the link or example circuit. However if I need to use opto for isolating, pls advise me.
Hi BabyTiger,
You can find the app note and source code here:**broken link removed**
If I recall, they do it without an opto-isolator.
Best wishes,
Robert
Take a look at the picture below ..
For 220Vac all you need to do is to increase the value of 10kΩ resistor to 18-20kΩ or use a 1.5µF capacitor (rated for 250Vac) ..
Regards,
IanP
Dear IanP
Could you describe this circuit?.
Why the 1.5uF capacitor can be used for resistor in 220V?.
Can I use 1.5uF capacitor in 110V?.
Could you tell me about working of D5 and R2?.
Thank you
1.5µF capacitor @ 230Vac will allow the same amount of current as 3µF @ 120Vac .. So for 110/120Vac operation you may use 3µF cap ..
D5 (11V zener) together with R2 (13.5kΩ) determine the width of th positive pulse on the Q1 collector - the higher the zener voltage the wider is the pulse .. R2 value is not critical, and yo may use anything between 4.7kΩ - 20kΩ ..
Regards,
IanP
Hi
You may use just a linear Transformer 220~5V.
and use your micro ADC to dectect zero crossing
Salam
Hossam Alzomor
www.i-g.org
Dear Ianp
Can I directly connect a ac input opto such as MOC256 to AC line without bridge diodes?.
Do you have formulas for calculating the value of your capacitor?.
Thank Creative_35 and ravimacus
Your links are good info. If someone have another good link or idea, pls tel me know.
Interface AC line
do u want to measure the voltage and frequency of the supply using microcontroller and display it in LCD or computer. Better you use a step down transformer. I had given some tutorials how to do it using parallel port of computer in my book
MY EXPERIENCE IN PARALLEL PORT INTERFACING
you can get it from yahoo group-booksbybibin
https://groups.yahoo.com/group/booksbybibin/
Interface AC line
About 20Mohm solution;
yes i have just tried and its working perfectly..optocoupler solution has some disadvantage due to led voltage drop..so pulse width is not exact 10ms...But 20M rsistor solution is perfect...
ps: ucontroller f628
Best Regards..
