huashizng
Newbie level 6
there are three fuse resistor used in the trimming circuit of the bandgap voltage reference. if the chip is taped out, how to determine the state of three fuse resistor ? below is my guess, i don't know whether it is right.
three trimming bits bring 8 states. we can select 8 chips. we burn the fuse resistors with different methods. so the 8 chips have different state . we should determine in which state the bandgap reference voltage is most accurate .
so we test the value of bandgap voltage in different temperature.(maybe there exist a especial temperature instrument ) according these tested data, the chip owns the best, zero temperature curve is selected. so the fuse of the remain chips will be burned with this same method.
the above method is just my guess, i don't know whether it is right.
who can tell me the method used in practice?
