Antenna (^.^)
Member level 3
How do I determine the track width of a pcb?
Also, what factors should I consider when making this decision?
Is it a power signal, as above current capacity.
230V is no current.
--> (power) Track width depends on current, not on voltage.
Klaus
@andre. Are you trying to say that when you measure the temperature rise for a PCB track of given paramterers, the temperature rise given by the calculation is "prohibitive"? really? Isn't a 30 mil track sufficient? I know there are websites on which one can enter the parameters of a PCB track and the website shall calculate the temperature rise of a given amount of current through the track
Where power is concerned I like to use copper pours where possible, more copper more heat dissipation...
