zhi_yi
Full Member level 4
x'cuse me, I have questions about transistor configuration,
1. if we want to for example create a common emitter with BC547, of course we need Vcc, beta value, and Icq, am I right or wrong? please correct me if i does any mistakes, okay, the question is, how can i know the value of Icq ? if the beta, we've already known it from the databook of BC547, it's said the beta value is 50, and then breakdown voltage for example 30 V, so I use 15 V, and then in the databook told me that the Icq max is for example 50mA. so, how much does the Icq should I use for determine the value of Rc, Re, R1, and R2?? (after i've known the Icq, i can determine the value of Ve = 0.1Vcc, and then i can determine the value of Re = Ve/Icq, and then Rc = 4.Re, and then vb, ib, and then R1 and R2)
2. which one should we determine at first? is it the value of Icq, and then I determine how much the gain of the circuit I want it to resulted. and then I determine the R, or i've to determine the value of the resistor for have the value of Icq?
thanks for the answer ^^
