How to determine amplifier's output impedance with Spectre?
fxxjssc
Member level 4
Member level 4
determining output impedance
Thanks
rout spectre
Put a AC current source with AC magnitude = 1, do AC simulation, then plot the voltage on that node, this is the impedance you want
spectre impedance profile
One trick.
Place voltage source with AC magnitude = 1V in series with output between output and load. Do AC analysys and measure current flowing though output terminal - Iout.
The output impedance Zout=1V/Iout.
amplifier output impedance
fxxjssc said:
supposing your amplifier has a one dominant pole, you can plot the Bode's diagram of the opamp gain and then calculate:
Rout=Aol/Gm
where Aol is the DC gain you can read from the Bode's plot
and Gm is the global transconductance of the opamp (which value also depends on with how many stages the opamp is built-up).
CBs.
You can also do Rout = Rup || Rdown. Find Rup and Rdown .
In the operating point results of MOS ro = 1/gds
