obrien135
Full Member level 5
- Joined
- Nov 10, 2009
- Messages
- 240
- Helped
- 5
- Reputation
- 10
- Reaction score
- 5
- Trophy points
- 1,298
- Location
- Connecticut
- Activity points
- 3,259
Helllo,
I am trying to design a Clapp oscillator and a buffer amp using an MPF102 field effect transistor. The data sheets I am able to find on the internet do not have much info. There are no charactoristic curves or max drain current specs given. There is a zero gate voltage drain current spec, but I'm not sure how to determine a quiescent point from that. Does anyone know how I should approach this or where there might be a batter data sheet? The MPF102 is the only part that Radio Shack has that will work, but the nearest electronics supply that might have it is a good distance and I'd rather not pay the shipping to order a different type of FET.
