michcfr
![Full Member level 1](/styles/images/ranks/elevel1.gif)
Hello,
I want to connect peripherals to a MCU with SPI in Master-Slave mode. The MCU is the master, peripherals are slaves.
Slaves are connected in parallel: I use 3-8 decoder from the MCU to select the potential 8 SPI peripherals (through their SS pin).
Do you know how the MCU can detect if SPI slaves are attached to the SPI-bus?
Regards,
Michel
Regards,
Michel
