How to detect rechargable batteries from normal batteries ?
ayeong
Full Member level 1
Full Member level 1
how to detect non-rechargeable batteries
How do we actually detect rechargeable batteries from NON-rechargeable batteries ?
My focus will be AA size batteries (NiMH, NiCD, Enegizer Photo Lithium and Enegizer Alkaline).
In order to implement a dT/dt fast charge termination, where would you place a thermistor ? which part of the body (e.g. positive terminal, negative terminal or the middle of the AA size battery) ?
Any links or ebook will be greatly appreciated :)
Thanks
Cheers,
Re: How to detect rechargable batteries from normal batterie
Almost the rechargeable batteries will mark with type of cemial that it used. The Ni-Cd Mi-Mh Li-Ion or lid asid type can recharge back other non
you should place thermistor near the battery. Temperature control is more important for Li-Ion than Mi-Mh and Ni-Cd.
I remember the resistor of these two batteries are different
This is a note for u make a refrence..
i find out some links to help you.
h**p://www.moltechpower.com/techdata/appmanuals/NiCd_Application_Manual.htm
h**p://www.moltechpower.com/techdata/appmanuals/NiMH_Application_Manual.htm
h**p://www.web-ee.com/primers/files/li-ioncharge.pdf
h**p://www.web-ee.com/primers/files/li-ionoverview.pdf
h**p://www.web-ee.com/primers/files/fsect5.pdf
